cwill925
May 13, 2014Explorer
hone eagle wrote:
The air bags primary job is to keep the suspension at a pre set level,(the driveline suffers vibrations if the angle varies.) They don't have a soft ride in my expirence .
Thats why the cab and seat have air ride.
Mr. Eagle is spot on. The air suspension on an MDT or HDT does not offer a soft ride. The rear suspension is rock solid, transferring the shock from the road directly to your fifth wheel hitch. Get an air hitch to save your trailer. I run a TrailerSaver TSLB2H, but there are others. Your Sportchassis should be set-up to bolt a TrailerSaver right in, at least mine was. I pulled the gooseneck ball out and the TSLB2H mounted perfectly.
TrailerSaver TSLB2H
