rexlion
Jan 04, 2013Explorer
What year is your GC? The big thing to watch out for is probably the hitch weight. If your GC has 5000 lb tow rating, the hitch rating is probably 500. I had a 2005 Rockwood 23 footer, and althoughI never weighed the tongue (I should have) it was heavy enough with full tanks to bend the left rear spring on my Mountaineer (6000/600 rating). It has a lot to do with where your water tanks are; the Rockwood's fresh tank was right up front, and added to 2 propane tanks, battery, and stuff in overheads above the front bed, it really added up. The overall trailer weight was fine at about 4K loaded, but heavy on the tongue.
The newer GC in particular should handle quite well IMO, but the wheelbase is short enough to make anti-sway desirable with a trailer of that size. Equalizer, Reese Dual Cam, Anderson No-Sway are some hitches to consider.
