Wes_Tausend
Jun 22, 2016Explorer
The odd thing is why would a relatively large displacement such as 7.3L develop excessive EGT's if newer, smaller displacement diesel engines do not also do so under the same heavy load conditions?
The answer must lie in choosing the appropriate "tuning", intercooler and turbo setup. So if one is determined to beat newer diesels to the top, it must just be a matter of more precise 7.3L tuning and some well thought-out parts that are still going to cost a lot less than a new truck with a puny engine displacement.
Quality parts and advice like Banks and some others come to mind. As an example, for 7.3L towing, Banks is almost certain to recommend a larger intercooler, or at least intake fluid injection (propane, methanol etc). This seems like the first place to start from an engine that is expected to perform more than the usual over-fueled stop-light-to-stoplight show-boating... an engine that is expected to perform at heavy uphill towing.
My parts choices, if I ever modified a 7.3L, would also possibly only include a larger turbo down-tube, saving plumbing bucks from muffler on back simply because the exhaust needs less and less volume as it cools downstream anyway. And on the other end, a better intercooler reduces the need for a downstream larger intake simply because the better cooled charge is denser, more compact.
For me, sound control is also a major issue after the first few minutes, which is the reason I would not prefer a silty K&N and noisy new airbox. I got more than my fill of extended over-the-road loud diesel thrumming at work.
And finally, just like our locomotives, transmission heat is a major concern and something to consider upgrading as a package. Banks usually recommends this too.
Granted, the old 7.3L runs dirtier nox-wise, but that is an EPA problem only. Admittedly, new smaller engines get better economy too, at light empty load that is. And some newer engines have somewhat more durable internals for extreme competition levels. But there is still no replacement for displacement when pulling. And at sane rpm levels, stock crank and rods are not a problem for the 7.3L.
Wes
Wes
