terminator35 wrote:
I have a question. I purchased a 2008 suburban with a 5.3 vortex engine and 3.73 rear. I want to know what size TT can I get in order to tow with the burb without burning it up? any help will be appreciated.
you probably should have started your own thread, since this one is focused on the OP's needs.
but i have an '07 Avalanche, which is the same as the Burb, without the rear seats and has a pickup bed in place of the seats.
same engine and rear end.
i believe your towing capacity is 7000-7200lbs., IF it has the factory tow package.
your payload is probably less than mine, since it's an SUV.
i tow a 24' HTT that weighs around 5000lbs. loaded for camping.
i wouldn't want to tow anything much heavier, but i live out West and have lots of mountain ranges to deal with.
you shouldn't go any longer than 27' ultralight and a yellow sticker weight of no more than 5000lbs.
and a brake controller and good WDH with sway control.
