carringb wrote:
kellem wrote:
drsteve wrote:
How many miles on your truck? It may not take kindly to the extra stress at its advanced age.
It's got 144K.
I'm not dogging it my any means, it's just a tow vehicle.
I wouldn't worry about those miles one bit. I had 456,00 when I burned up that valve seat. And if I hadn't let the fuel filter go long (90,000 miles :e) and didn't let my storage compartment flood the same weekend, nothing would have happened. And, I drove another 4,000+ miles with just 9-cylinders before I had time to drop it off for service.
BTW - one more special service note: Make sure you regularly clean your MAF if you're running an oiled air filter. The oil can coat the MAF wire and also cause a lean condition.
Yep, I run that kind of filter and yes, clean the MAF sensor wires often. Good point.
That's a ridiculous bunch of miles you got out of the Hemi.
