bid_time wrote:
atreis wrote:
While this is true, there are two limits that ARE legally enforceable: the axle weight rating, and the tire weight rating. Exceeding either of those can land one into hot water, which might be possible given the neighbor's setup. (Especially the tires.)...
I sure would be interested in knowing what law you're citing that make these ratings "legally enforceable".
This is for tires. I couldn't find the specific regulations for axles.
Tires (GVWR 10K or less):
https://www.law.cornell.edu/cfr/text/49/571.110S4.2
or (more than 10K GVWR)
https://www.law.cornell.edu/cfr/text/49/571.120S5.1.2 and S5.3.1
Assuming you drive over 80kph.
