lawrosa
May 30, 2014Explorer
Have the hitch people look and see if you have one. Even if it has one its probably small. IMO have one installed when you have the hitch installed. Put the biggest one you can fit behind the grill..
Yes if the trailer is too heavy you can burn the trans fluid while driving. And without a temp gauge you will never know. ( Install a temp gauge too)
That alone will cause the trans to fail sooner then later.... And when you get that $3200 new trans bill you will wish you put in a $60 trans cooler...
