willdennis's avatar
willdennis
Towing w/out weight dist -- am I being too conservative?
Hi all,
I have been towing since 2010, first with a 2010 Chevy Silverado 1500, where on the first TT I had (bought used) I used a Reese WD hitch that came with it (Dual Cam model), but then went to a ProPride 3P when I got my current TT in 2017. In 2018, I got a much better TV (GMC gasser 2500) which of course has a much better towing capacity, and kept using the ProPride with that.
After my first trip of this season, I noticed the ProPride hitch head on the TT didn't move as smoothly as it should, and removed the top pivot "hubcaps", and found that the left-hand bearing assembly was all rusty (water intrusion) and that the topmost roller bearing had cracked open (!) Towed it over to my RV mechanic who inspected both upper pivots (each contain two roller-bearing assemblies) and he tells me all four are bad! (who knows about the bottom two pivots bearings...) So, because of this and other PP issues (hitching can be a real drag), I'm done with the ProPride... Told my RV mechanic to remove it from the TT, and he did.
But, dumb luck, my sister's boyfriend just got rid of his TT, and has a 2008 BlueOx SwayPro with 1000-lb bars that he's glad to loan to me, so I went over and got it from him. Unfortunately, my RV mechanic said he will not install any hitch that he doesn't sell (and at present, he can only get Fastway e2 hitches, which I don't want.) So, I'm faced with towing the TT just on the ball, at least to another place that installs customer-provided hitches (I actually found one that's 15 min's away from my RV mech.)
Both my RV mech, as well as my wife who looked in my GMC owner's manual, asked why I couldn't just tow on the ball without a WD hitch from now on (we were supposed to go out on a trip yesterday, which got cancelled anyways for other reasons.) The owner's manual says that WD hitch is "Optional" with TT weights of up to 20K lbs (my particular model is rated to tow up to 13K lbs max.) I guess I'm just (a) used to towing with a WD hitch, and (b) very conservative saftey-wise (don't want any harm to come to my family, and secondarily the TV which I love, or the TT, from being involved in a towing-related accident...) Am I being way too conservative here?
Relevant facts:
- unladen TT weight: 5225 lbs
- TT GVWR: 6250 lbs (guesstimating that our laden TT is +/- 6000 lbs)
- est tounge weight: 750 lbs
- calculated max TV tounge weight: 1100 lbs
Your thoughts please?
