DoneItAll
Nov 18, 2013Explorer
Towing
My F450 is equipped with a stock class V hitch. Am I correct in that I would only need a TorkLift SuperTruss Extension Bar to be able to tow?
Thanks,
John
Thanks,
John
SoCalDesertRider wrote:Mello Mike wrote:Wayne, I've been hearing about your hitch for years now. This is the first time I have seen it. I like it. :)Reddog1 wrote:Thanks, Wayne. I understand now what you're saying about the tubing for the side forces. Looks pretty sturdy. :)
This is an old (2004) photo. The extension uses 2"x2" 3/16" wall tubing in instead of chains, for the side forces. Way overbuilt, and adds unnecessary weight to the truck. I have chains to replace the tubing, but keep using it for other projects. I have the tubing on the truck now, but again I will replace the tubing with chain.
06Fargo wrote:So it's a removable chain link? Or a shackle? A picture would help.SoCalDesertRider wrote:From first hand experience: It's the piece of rigging (related to a skyhook) that's missing when you attempt to cross the safety chains to prevent the trailer from grounding if it uncouples, while at the same time extending the chains to the tow vehicle frame. Thereby requiring a 30 min drive to town and going to 6 places to buy $100 worth of shackles, b**tch links, pins, connectors and such, none of which fit...
What is a kiniffle?
My crossed chain rig up/chain extensions/ shackles and bits was a thing of beauty to behold when my DW comes along and says "How many things have to break at the same time for that Super Truss thing to fall off the truck?" Me: "Um,1,2 5/8" pins, 1, 2 3/8" pins so that's ummm four! Not counting the sway chains1" DW: "Like you're not going to notice that and stop?" Me: "Ummm ya I guess so..."
What is a kiniffle?
joe b. wrote:
When I first set up our previous Dodge truck I bought a 48 inch extension, which turned out to be much longer than I really needed. With our Lance 845, the overhang in the back is not a great deal. But I failed to figure in that the Jeep tow bar attachment points, are 16 inches in front of the grill. Then I added a Ready Brake auxiliary system to the Jeeps and that added an additional 20 inches. So the two of those factors added 36 inches to my setup. Then the Falcon 5200 tow bar added 6 or 8 more inches where it slides into the Ready Brake receiver. So then I bought an 18 inch extension and stopped using the chains, then checked it without the 18 inch extinion and it works just fine. Took it to an empty parking lot and made tight circles, etc and check how close to the rear corners of the camper I was getting with the Jeep. Not a problem so currently I just use the Ready Brake off the factory Class 5 hitch, then the tow bar off that, then the Jeep.
Could have saved some money, if I had taken a better look instead of going with the trial and error method of measuring. But, if we do trade up to a larger camper, with more overhang, then the 18 inch extension will come in handy.
Original set up with 48 inch extension.
Here is the our current tow using just the Ready Brake and the Falcon tow bar connected to our current Jeep Unlimited. Towed it from south Florida to North Dakota, Wyoming, Montana, Utah, western Colorado, and back home through Arizona and New Mexico. Worked fine, in the closer coupling, than the original set up with the red Jeep.
vanderjw wrote:The Superhitch/Supertruss is indeed a very well designed and well built product, as are all of Torklift's products, that I have seen so far. :)
I have a Superhitch and a short Torklift extension. I would recommend the Torklift parts if money is not a concern. The system works very well and I don't have to worry about the hitch failing and injuring someone. I tow about 7,000 lbs.
