I suspect you'll be a little surprised at the ACTUAL weight of the trailer. If the brochure says 7000 lb. it'll likely be closer to 7500 before you begin loading anything in it. USUALLY any optional items are not included i the dry weight or UVW of the trailer which is used in the brochures. This often includes even "forced options" such as stab jacks, batteries, TV antennae, patio awning and many other common things. It is ALWAYS much better to consider the GVWR of any trailer you plan on towing and use 15% of that weight as the fully loaded tongue weight. You have a VERY capable truck but some models tend to be very light in the payload department so those are the numbers you need to check carefully. If the math works out then you're good to go.
Good luck / Skip
