lanerd
Sep 23, 2015Explorer II
I've had Pressure Pro on my previous motor home and toad and transferred them to our new motor home an toad and after almost seven years, I have only experience one time when the sensor vibrated loose a little bit causing the sensor to stop sending. My monitor immediately notified me that I had lost connection and at the next stop, I found and tightened the sensor back on and have never had another problem with it. I do, however, now make it a point to check the sensors prior to travel.
Our new toad, 2011 GMC Terrain, came with factory TPMS and I have never experienced a single problem with it in the 75,000 miles we've driven it and the 10,000 miles we've towed it.
Checking your tires prior to travel is a good thing, but does nothing when your going down the highway at 60mph and you run over something that causes a tire to start leaking. If the leaking continues, the tire will eventually come apart and cause lots of damage....much more than the cost of the TPMS.
You mentioned: "I dislike them because it gives you an excuse to NOT do what you should be doing on a regular basis."
Just because you have a TPMS, does NOT relieve you of your responsibility to check your tires prior to traveling. The TPMS will warn you of leakage, but will do nothing to tell you of cracks, bubbles, rocks, or other debris that tires (especially duals) can pick up that will cause damage.
TPMS is a great safety device that every rv'er should be using.
Ron
Ron
44,067 PostsLatest Activity: Jun 05, 2026
