GMandJM
Sep 24, 2015Explorer
Coolerman wrote:
I searched and found the other 6 page thread on the TST system. That thread is more about the loss of the sensor connection to the monitor and that taking an hour to report to the user. So far no solution to that has been presented. I guess I will hold off and research more before buying.
You're right: There's no user-setting on our TST monitors to shorten the duration for a lost sensor signal alert.
I've tested mine and the monitor gave memory readings for nearly an hour when the monitor was miles out of sensor range.
FWIW, I got an e-mail from PressurePro that stated:
"In the case of a "missed" signal, the miss generally is recognized at the 5 minute update with three dashed lines, - - -, and the tire location that was missed is highlighted. In most cases, the sensor signal will pick up on the next 5 minute update. The longest you could possibly go without being alerted to a "missed" signal is 5 minutes."
I don't have the PressurePro system, so I cannot confirm that.
If anyone has the most recent PP system and is willing to test it for us, alot of us would probably appreciate it.
44,067 PostsLatest Activity: Jun 05, 2026
