RinconVTR wrote:
Who has added TPMS to their TT or other trailer? A whole bunch of rv'er have.
Either as cap, or complete valve replacement, which system have you chosen? As a cap on the valve stem.
How much did you pay? My initial system was a 10 tire (6 on the mh, four on the toad) unit from Pressure Pro. I then up graded to a 16 tire unit for our new coach (8 on the mh, four on the toad...and have 4 left over). Initial unit cost me about $550 and the new 16 tire monitor plus two more sensors cost me an additional $300. Not cheap!
What are the pro/cons of what you installed (your opinion of the system, not the pro/cons of TPMS)? Pro is total coverage of all tires that allows me to monitor the tires as I travel. Con is $$ invested. But, one blowout could possible cost me much more than the cost of the TPMS.
Has it ever saved you from a blow out? Or did a blow out occur while you had TPMS? Twice I've had tires on the motor home (previous coach) pick up nails that caused a slow leak. The TPMS alerted me to a low pressure situation given me ample time to pull over and get the tire fixed. Yes, I did have a blow on the the toad that was instantaneous with no loss of pressure prior to the blowout.
FWIW, for the purpose of evaluating a TPMS system, a mh and toad is basically the same thing as a tow vehicle and a trailer. I would highly recommend that you do a search on "TPMS". You'll find a whole bunch of information.
Hope this helps
Ron
