SarahLichtman
Feb 18, 2016Explorer
Hey guys it's Sarah at TST. Just jumping in about signal loss. If your set up is getting past a certain length, say 28 feet, you'll probably need a repeater. It's not very expensive, and it's a plug and play device, no setup, easy. Once you've plugged that in, you'll have no issue with signal loss, unless you have some other issue, which can always be worked out and fixed if you let us know. Some folks need the repeater and some don't. It just depends on your coach and what other electronic equipment you have running etc. I recommend buying one and if you end up not needing it, full refund. No problem. I'll keep an eye out to answer any other questions. Thanks all!!
44,071 PostsLatest Activity: Aug 30, 2026
