PUCampin
Jun 10, 2016Explorer
Congrats on your truck! Don't worry too much about the gear ratio, the wide ratio of todays 6spd transmissions almost makes the rear end irrelevant. The 6R80 has a 1st gear of 4.17:1, so even with a 3.15 rear end, your first gear is still lower than the old 4spd was with a 4.10!! The rest of the gears in the 6R80 are spaced very nicely with 4th being a slight underdrive at 1.14:1 instead of direct 1:1, which is like being in direct with a lower rear axle. The torque of the ecoboost will make up for the 3.15, and it will help your unloaded mpg. Enjoy your truck!
44,056 PostsLatest Activity: Nov 19, 2013
