- Dick_BExplorerThis year I'm going to bring along a portable radio and compare reception. I'm betting on the portable.
- modern_familyExplorerWhat is AM radio. That is still around ;)
- WyoTravelerExplorerThe antenna on your RV is very short. Basically in the VHF range of FM. You won't get great AM reception. However, some of those little antennas are better than others. I would check to make sure the antenna cable is connected. My MH is mostly fiber glass. I was receiving FM without the antenna being connected. Once I plugged in the antenna I had great reception.
- old_guyExplorereven in my car and truck listening to our local AM station is bad. I have to turn the volume up so high that when DW tunes in her FM channels it blasts her out of the car.
- n7bsnExplorer
TheGriswolds wrote:
My FM radio works fine but can't seem to get anything on the AM dial in the trailer. Are the antennas that bad for AM or maybe something is disconnected. Anyone else have bad AM reception?
Assuming your radio is connected to it's antenna, and it probably is if you are getting lots of FM stations since most use the same antenna. The problem may, and probably is, not with your radio but with the other "stuff" in your rig.
Your AC to DC puts out a LOT of radio interference (RFI). Unplug your rig and see if the AM radio is better. Make certain your inverter (if you have one) is off too, they also can generate RFI.
It is possible that the control board on your refer is to blame, but this is less likely.
Also your blower motor on the furnace can generate RFI. - n7bsnExplorer
dockmasterdave wrote:
AM is also much more affected by distance from the station. Frequency modulation (FM) follows the curve of the earth much better. FM is also far less affected by interference from normal things around us. Hope I have those right or my dad will be disappointed. These were his teachings to a 6 year old wondering why I got some stations and not others.
Well....
FM does not (period) follow the curve of the earth and AM does
While FM is far less affected by interference then AM
So you didn't get it all wrong. - stubblejumperExplorerIf you can reach in behind the radio, check that the antenna plug is fully inserted. The stiffness of the cable from the antenna makes it more susceptible to shaking loose than standard flexible braided wire.
- TheGriswoldsExplorerI remember driving from Atlanta to Cincinnati on a clear night and in TN I was getting the Reds game on 700WLW, it was a clear night. I guess when we are camping there are usually trees real close and that can't help. Oh well, at least it's not just me and there is always IHeart radio for those must listen to games. Thanks for the input
- dockmasterdaveExplorerAM is also much more affected by distance from the station. Frequency modulation (FM) follows the curve of the earth much better. FM is also far less affected by interference from normal things around us. Hope I have those right or my dad will be disappointed. These were his teachings to a 6 year old wondering why I got some stations and not others.
44,050 PostsLatest Activity: Mar 24, 2021
