Hi, I have a 2011 keystone summerland. I have noticed that when I go around curves like a coldest that the front and rear axles are not aligned. They have a different camber. But after driving in a ...
All is normal for a trailer with the wheels towards the center of the trailer.
By floating axle means the axles have a equalizer bar that allows multi axle to step or some call it float over a obstacle vs a hay trailer with no equalizer bar.
Tires will side scrub as your trailer tires did with either design
