NCMODELA
Apr 12, 2014Explorer
trailer axles
Hi, I have a 2011 keystone summerland. I have noticed that when I go around curves like a coldest that the front and rear axles are not aligned. They have a different camber. But after driving in a ...
Terryallan wrote:Do you have a link to anywhere that has happened?NCMODELA wrote:
Hi, I have a 2011 keystone summerland. I have noticed that when I go around curves like a coldest that the front and rear axles are not aligned. They have a different camber. But after driving in a straight line they shore back up. There is no irregular wear on the tires. Is this what they mean by floating axles?
Thanks bill
Yes it's normal. Also when backing in, and turning sharply you will see the tandem out of line. It is best to always back far enough to be able to pull up, and straighten them out.
But that is why trailer tires are built differently tan TV tires. They are designed to slide sideways in a turn, and not pull off the rim
