Hi, I have a 2011 keystone summerland. I have noticed that when I go around curves like a coldest that the front and rear axles are not aligned. They have a different camber. But after driving in a ...
The concept of tandem axles in a turn has been explained very well. If you think you have strain with tandem axles in a tight turn, think about what happens with triple axles. In fact, some rubber torsion axle manufacturers don't recommend even using those axles in a triple axle configuration.
