SailorGuy's avatar
SailorGuy
Trailer brake advice
Hi
Just purchased a 2015 Outdoor RV 20FQ (4400 dry/6200 GVW). I need to tow it home (35 miles). I currently have a 2008 F150 V8 pickup which I will replace next month with a newer truck. Current F150 has factory tow package (hitch, 7pin, transmission cooler and 36 gallon gas tank) but no trailer brake controller.
I don’t want to tow the trailer home without trailer brakes but I don’t want to spend a lot of money on the truck since I will be selling it next month. One option I found was the Curtis 7pin plug in trailer brake controller which uses an iPhone app to configure the controller. Anyone have any experience with this product?
Alternatively I could have the local hitch shop install an after market controller at a cost of $300 to $400. I’m pretty handy. Could I buy a controller at Amazon and install it myself? How hard is it to install?
The trailer seller is including the WDH he used to pull the trailer so he and I will set this up when I pick up the trailer.
I rented a similar trailer last month for a week and used the rental companies WDH and wireless brake controller since my truck doesn’t have a trailer brake controller. The rental trailer towed fine.
Advice/recommendations?
TIA
SailorGuy
  • My truck is a 2007 Chevrolet Silverado. I bought it used and later bought a Puma 25RS. I ordered a Prodigy P2 Brake Controller from Etrailer. I drilled the mounting holes in the dash and then plug it into the truck circuit board, no problem. I set the controller up myself...
    On the WDH...when I bought my trailer they set up the hitch...when I got it home I redone it after I had my trailer loaded. I did have to tweak it after pulling it on the highway. I did it myself...several years ago.
  • You absolutely can do it yourself, it's easy.
    For a tow home buy the cheapest time based controller you can find. The install is pretty much plug and play. Here's a $37 controller plus a $15 pig tail to plug it into the truck.
    Link
    Link
  • “I don’t want to tow the trailer home without trailer brakes but I don’t want to spend a lot of money on the truck since I will be selling it next month.”
    As long as you don’t hit or kill anyone on your way home, including yourself, it is a go to drive without trailer brakes. Glad to hear you’ll be level with the WDH. Form over substance.
