JIMNLIN
May 23, 2018Explorer III
Those that pull heavy GN trailers for a living SERIOUSLY prefers drum over disc in the long run.
I know when I was pulling on the road disc brakes stopped my trailer better wet wet which wasn't very often but overall drums performed better. When you put 80k-100k mile a year on a trailer you learn a lot about things like brakes/wheels/tires.
When I put a trailer in service I go through all the wiring before putting one in service making sure the brakes get the required amps (not volts. Doing away with those clam shell crimps is #1 prioriety.
I wouldn't pay extra if it was a option.
No more than you will pull the trailer drums when set up properly will work fine for you.
However if I was wanting disc brakes I would get them.
