carringb
Jan 20, 2015Explorer
brulaz wrote:carringb wrote:
Also, I plan on upgrading to dis brakes with ABS (to also address the above issues), which effectively requires the DirecLink.
You can do this ??
And why does it require DirectLink? (or an IBC?)
It would be a separate ABS system, independent from the truck's, no?
It is separate from the Tow Vehicle's ABS, much like all modern semi-trailers. It piggybacks and ABS module onto a hydraulic brake actuator, and uses new wheel speed sensors on the trailer to detect slip and module the trailer brakes.
I'm not sure on the particulars of what information is communicated between the DirecLink and the "ActuLink" actuator. I suspect it uses the TV's wheel speed as a reference speed for when to activate ABS.
http://www.direclink.com/abs.html
