camperforlife wrote:
I have the integrated controller on my 11 GMC. Compared to the three past aftermarket controllers including the Prodigy that I have owned, none can come close.
I agree, though I did have a BrakeSmart controller, which operated just as smoothly as an integrated controller on my 2009 Silverado.
BrakeSmart is similar to the MaxBrake, in that it senses brake fluid pressure.
When you have a brake controller that sends out a signal to the trailer brakes based on hydraulic pressure, or movement of the brake pedal like the Jordan does, everything is smooth and seamless with regard to trailer braking.
With a brake controller that relies on a small amount of g-force that occurs when braking, like most any other brake controller (Voyager, Prodigy, etc) there's a very short delay after you hit your brakes before the trailer brakes start being applied. If you apply the truck brakes ever so slightly, you may not even get enough g-force to occur to even cause the brake controller to realize it needs to apply the trailer brakes.
The bigger and heavier the trailer is, the more noticeable the above becomes.
I encountered this with my toy hauler, which was around 7500+ lbs loaded. The brake delay was unnoticed on my little 1000 lb cargo trailer.
Another example of the annoyances was that the amount of trailer brake activation wasn't consistent - it varied or was non existent with light truck brake application.... again, this was very pronounced with the heavy toy hauler. I was continually fiddling with the Voyager brake controlled I first had. I eventually sold it to a friend and upgraded to a Prodigy. The fiddling was less, and I could use the boost function to do my "fiddling".
I'd run on no boost when driving around town and dial it up to B2 when I was on highways.
With the Voyager, if I set it to a given setting where it wasn't too jerky on surface streets, I didn't have enough braking action at higher speeds. If I set it to give me good braking action at highway speeds, then the braking was too aggressive on surface streets. When I upgraded to the Prodigy, the boost function helped with this. With either brake controller, I never could find a happy medium of "set it and forget it" when towing the toy hauler.
The voyager used a "pendulum" to monitor the G-force. It had a dial on the side to use to set the angle you had it mounted it.
The Prodigy is a bit more intelligent and uses an accelerometer (if I recall correctly) so the delay on activating the trailer brakes is almost non existent, unless you very lightly apply the truck brakes.
I began to get tired of always fiddling with the boost function of the Prodigy, and the jerkiness on surface streets if I tried to find a happy medium that gave me good brake action at highway speeds.
I had read a lot about the Jordan and the BrakeSmart, and one other one that I forgot the name of - they were the only "smart" brake controllers at the time.
About a year went by before I finally convinced myself to get a BrakeSmart (which is no longer available.) That was in 2006. I'd had the toy hauler 3 years at that point in time.
NIGHT AND DAY difference!!
The trailer brakes are seamless, and operate in complete unison to the amount of truck brakes I apply. No more jerkiness, no more fiddling with settings for highway or surface streets, no more clanging and banging of the hitch when the trailer tried to stop the truck because the setting was too high.
I used the BrakeSmart until I sold that truck in 2009. In 2008 my brother bought a new Silverado dually and told me about the integrated brake controller (IBC). I was determined to get an IBC in my next truck. I upgraded to a 2009 dually in the fall of 2009.
The smaller and lighter a trailer is, the less annoying a "dumb / old school" aftermarket brake controller is, because you won't notice the annoyances I described above.
Once a person experiences the seamless operation of a smart brake controller or IBC, then they realize what they missed out on!
The new truck has 30000 miles on it now, about 25000 are with a trailer behind it. I downsized to a truck camper. I still have trailers though, and always am towing something, either with the camper on the truck, or without the camper.
Just like with the BrakeSmart, I love the seamless operation of the IBC. The only time I fiddle with the setting is when I switch to a different trailer, or if my load in a given trailer is different than the previous trip and warrants a change in brake setting.
Earlier this year I used my dad's truck, a 2006 Silverado, with a Prodigy brakes controller, to tow the trailer below on 3 trips, about 650 miles round trip, loaded heavy. 20 miles or so were on surface streets at the end of the first leg of the trip, and the beginning of the return trip. Stop lights everywhere. I was fiddling with the settings when transitioning between highway and surface streets again, the hitch was clanging and banging, which it never did on my truck. It was a nice reminder of how much better an IBC is.
The benefits of smart controller or IBC become much more apparent the bigger and heavier a trailer is.
The big trailer:
The small trailer:
