I have a 2011 Coachman Catalina 22FB. The black/gray water dump valve has between and 5 and 6 inches of ground clearance. This seems really low compared to other campers. Is this low clearance going t...
It all depends on how far away from the axle they are. If they are very near the tire, they will likely never drag unless you like to go busting over curbs. The farter away from the tire they are the more and more likely they may drag when encountering a steep change in grade.
