ktmrfs
Oct 16, 2015Explorer III
opland wrote:
I was going to express skepticism about dehumidifiers being the perfect solution to condensation problems because my dehumidifier can't remove enough water from the air to be called effective. Based on comments posted in this thread, apparently my dehumidifier is too small for the task. I never could open the trailer up enough to eliminate the annoying condensation and stay comfortable. Seems the answer is go big or stay home. :)
there are dehumidifiers and there are dehumidifiers. Some are small and use a thermoelectric element. IMHO not worth a darn. they will extract maybe a quart of water/day. less than what you produce from normal persperation.
The good ones are a refrigeration unit that has an exposed refrig coil that lowers the temp below the dew point and extracts moisture. Even a small roll around unit will extract 6-10 gallons of water/day in high humidity conditions. These work well. Thats what we have. figure around $100 for such a unit.
44,066 PostsLatest Activity: Jul 25, 2018
