ktmrfs
Oct 17, 2015Explorer III
Chuck_thehammer wrote:colliehauler wrote:Mikesr wrote:Read Ktmrfspost. Small units are not very effective in humid conditions. I think they make a 25 pint and a 30 pint that uses a refrigeration unit.
I've been following this thread and reading about the use of a small dehumidifier. Can anyone recommend one that would store easily in a TT ? Our home dehumidifier is a large 60 pint unit that works well in our basement but I could not imagine lugging that around in a TT.
I have been doing research on this issue..
30 pint per day is about the smallest with a compressor... I have found and about 150 in price..
I have a 70 in the basement... big, heavy, noisy....
and a 30 is about 30 pounds.
as this winter will be our first time using the travel trailer in the winter... even in South Carolina.. cool/ heat on...
last month.. in Ohio we fogged up all the windows in our 30 footer... making food for supper... Now we RUN the exhaust fan when cooking.
the 32ish pint is a good size for a trailer. 32 pints=16 quarts=4 gallons. in an area with high outside humidity, it may initally fill the bucket in 8hrs or so, then go 12-24 depending on conditions. and it is small enough to easily move and roll around and store. that is around the size of what we have. IIRC 32 pints is about the smallest compressor driven unit.
BTW there are only 2, maybe 3 mfg of ALL these compressor driven humidifiers, then multiple brands. haier is one of the mfg. the units can be found at lots of big box stores/amazon etc.
BTW when I said "small" I was referring to the units that have maybe 2-8 pint capacity using a thermoelectric element (peltia), no compressor.
we have used ours now for 3 years, and we camp 3 months/year.
you most often need the dehumidifier when outside humidity is high. in that case your near the dew point, add moisture from you, cooking etc and all the sudden inside is near the dew point, drop inside temps and cold windows= condensation.
44,066 PostsLatest Activity: Jul 25, 2018
