ktmrfs
Oct 19, 2015Explorer III
tnrv'er wrote:
Probably a dumb question but do you get the same kind of condensation problems with 4 season campers??
you still could. If the "4 seasons trailer" has single pane windows and/or aluminum window frames, you'll still get window condensation.
The higher the indoor temp, the less condensation. so the better insulated (especially if heat is off/down at night) the higher the temps will be so that helps.
but still your putting about the same amount of moisture into the air from cooking, perspiration, showering etc. that you would in a 3,000sq ft stick house but into 300 sq ft. so inside RH will be much higher in the trailer, hence more chance of condensation.
44,066 PostsLatest Activity: Jul 25, 2018
