GregAExplorerDec 29, 2021Trailer connectI have a question regarding "Trailer Connect" on my Ford F350. I have both a 5th wheel and slide-in camper. The 5th wheel seems to just "connect" if the truck is running. The Slide-in camper only ...Show More
kohldadExplorer IIIDec 29, 2021Since the truck is sensing the resistance in the trailer brakes, you could add a resistor to the trailer brake pin. I've never done it but did a quick search and found this thread which did describe a solution down on 1/20/2015. https://www.f150forum.com/f38/can-i-fool-my-trailer-connector-into-thinking-i-have-electronic-brakes-286312/index2/
Related ContentQuick connect exterior shower hose doesn't connect.Nautilus P1 has leaking connectionsTravel Trailertrailer connection issuesMy Travel Trailer Fell Down
