I am new to travel trailers. Mine got delivered yesterday. Today the carpet under the dinette and sofa are flooded but I can't tell where the water is coming from. My landlord hooked it up to city...
Hopefully you have turned off the city water source. Is your fresh water tank full? We don't know what kind of trailer or hookups you have. Is your fresh tank a separate gravity fill, or does it fill from the city water source, by using a bypass? A little more info would be helpful.
I would just use the tank and pump, till you get it figured out. If you have a leak somewhere, you will notice the pump run a little, when the water faucets are turned off.
