jfkmk
Mar 21, 2015Explorer II
SoundGuy wrote:Quality Johnson wrote:
I have to replace the vinyl flooring in my older 19' Dutchmen TT because it split from end to end in the cold of the winter of 13-14.
What's the easiest way to do this that ends up with a decent result?
Just a suggestion but you may get more response to your query if you make it clear in your title that it's the vinyl flooring you're wanting to replace, not the floor itself. As far as replacing the vinyl flooring is concerned I have a friend who did this exact repair to his Starcraft TT and has detailed the repair here. I remember following his progress at the time and his approach wasn't for the faint of heart but the results were outstanding. :B
I checked out the install...what a beautiful job! It also underscores the amount of work involved if you want to do it right.
