westend
Mar 23, 2015Explorer
Precut a piece off the roll that is a bit wider than the widest point you have to cover. Get a very good and sharp linoleum knife and blades and go to work. If you misjudge an area then put in some molding/trim.This is exactly why I suggested an installer handle it.
FWIW, I installed flooring for about 9 years and that is not the way to get it done right. I could write out a detailed instruction sheet for it but there are some things that experience brings that can not be covered.
