Lynnmor wrote:
Gdetrailer wrote:
As far as strength of the hitch pin goes, don't know exactly, but the same diameter pin is used for 2x2 and 2.5x2.5 hitches.. Just the length of the pin is longer for the 2.5 hitches.. Can't say for sure on the 3x3 hitches but I suspect most likely the same diameter to allow compatibility for using an smaller hitch accessory like a bike rack or lighter weight hitch via adapter sleeves.
Nope, the 3" uses a 3/4" pin. I think that most are using a 5/8" and that is unsafe. Those using adapters would need to drill the holes larger on the adapter and the shank, do you think that ever happens?
Like I said, I wasn't sure on 3" hitches, I personally have 2.5"x2.5" hitches and the hitch pins ARE the same diameter as 2x2 hitches I used to have. The only difference between 2" and 2.5" hitch pins are length..
Need a longer pin for 2.5" hitches..
If 3" hitch uses 3/4" pin then one could use a 5/8" diameter pin provided it is long enough and even though it would be a sloppy fit so yes, one could use a bike rack designed for a smaller hitch..
Not saying it is a good idea, I personally didn't care for the slack with 2" to 2.5" sleeves so I upgraded my hitch shank and even the upgraded hitch shack had too much slop so I welded beads around the shank to get rid of the slop.. Not many people would be willing to weld and grind the hitch shank to fit properly.
But back to the subject, I try to check to make sure no one has tampered with my hitch from the pin to the hitch head, chains and even tether cable when ever I stop and leave the vehicle out of sight.. Just makes me feel good that all is the same as I left it.
Pin for 2" and 2.5" hitches are sturdy enough for the loads they get, basically they are in a "Shear" type of use, takes a lot of pressure to shear cut off 5/8" bolt but keep in mind you have to shear off TWO SIDES at the same time.. Basically the same as shearing 1.25" diameter bolt..
According to
HERE A 5/8" hitch pin should be close to grade 8 bolt specs.. Which would have 150,000 lb Tensile strength.. Shear mode is typically 60% of Tensile strength..
So, 5/8" hitch pin should be good for around 90,000 lbs..
But wait, there is more, that pin HAS to shear off in TWO points of contact at the same time in order to lose a hitch so now we are looking at 180,000 lbs!
That is 90 TONS of shearing pressure required..
I suspect the hitch components will fail before the pin..
Also don't assume since you may have a locking pin that it WILL stay locked either..
