Ozlander wrote:
maxwell11 wrote:
hubs have those pop off covers with grease buddies, where grease zerk in right at the end of the hub, I normally give them 3 shots of grease, two or three times per season.??????
I think that is too much grease. Where's the extra grease going to go? Going to mess up the brakes.
Maybe 3 shots a year. I don't grease mine but maybe every five years.
How often do you grease the hubs on your TV.
The extra grease comes out of the front of the hub. You pump grease into the zerk which is in the center of the hub. It goes through the bearings and returns to the outer part of the hub. When you see grease coming out around where you are pumping it in, you know that's enough.
