Anyone have any suggestions for a trailer jack for changing a tire on the side of the road in an emergency, for a double axle? I tried driving the good tire onto boards, but due to the type of suspen...
I use a screw jack I found at a thrift shop, I think it came from a Dodge pick-up. I shaped a long steel shaft so that one end fits into my 19.2 drill motor, and the other into the rectangle shaped receptical at the bottom of the jack. So the drill will raise the jack really fast and has enough power to lift the TT or Suburban off of the ground. It's also fairly short so it does fit under the axel. Also a lot lighter than the bottle jack.
