rsaylor3's avatar
rsaylor3
Trailer leaning?
Ok, granted I have a spare tire on there now, getting new tires in a few days, but I noticed that the trailer is leaning a bit when connected to the truck and when parked on level surface.
It is the heavier side of he camper that it's leaning towards. I am guessing the spare tire is part of that issue, but is it normal for the trailer to lean slightly to one side?
  • fla-gypsy wrote:
    Have you inspected the suspension on the low side? Not uncommon for springs, hardware or hangers to break.
    That right there ^^^
    Check for a broken spring hanger or shackle.
  • Have you inspected the suspension on the low side? Not uncommon for springs, hardware or hangers to break.
  • Dutchman, I think you might have it. I never noticed it before last weekend coming home with the spare and that caused me to be slightly more on edge and looking at everything. I first noticed it at a rest area in the semi side and I do think the spots are all slightly angled. My truck didn't look like it was leaning but the trailer did from the front and back, but you are right it is a lot taller and would throw the eye that much more. I will go park on a nice level parking lot after I get my new tires installed in ten days.
    Thanks guy's!
  • Have a reliable mechanic look under your tow vehicle and check the sway bar endlink mounted under the truck.
  • It is possible if you have slide out one side, that side of the trailer is heavier and could cause a lean, even with the slide in. (but usually no.) The slide mechenism goes across the trailer and the weight of the slide should distribute to both sides. But depending on the way it's made, it's possible.
    One tire should not make it lean. But, in order to test the theory, why not remove the spare and see if it still leans?
    Did you notice it leaning before, or is this something you just now noticed? Meaning, something might have changed to cause it to lean. How is the inside loaded? Lots of items on one side and not on the other? Here again, if so, try moving things around inside and see if that makes a difference. Normally, it should not. But if your springs are worn, or broken, or something out of whack, it will continue to lean no matter what you do. So start first by simply moving things around and see if you can get it level again. Normally, trailers are not "THAT" touchy. Something could be wrong. But, there again, if a LOT of weight is on one side, that might be all it is.
    Edit:
    And here again, are you sure you are on a level surface? Even a slight slope can make the top of the trailer (10 feet tall) look like it's leaning a lot, when it's really not. 1/2 inch difference in the rise of the tires, could cause the top of the trailer to lean a few inches (10 feet up). That might be all there is to it?
