I like it. I also have two LED backups that I added near the front like you did. It makes it a lot easier to back up when out in the desert at night. It also makes it a lot easier to deal with leveling blocks and stabilizer jacks as I don't need to hold a flashlight in one hand.
Have you added a switch so you can turn the lights on even when not hitched up? Currently mine are only wired to the backup circuit on my Suburban. But I found that many times I need to get out and do something while leaving the lights on. The only way to achieve that now is putting on the parking brake and leaving the truck in reverse which I'm not too keen on doing.
