hawkeye-08
Apr 07, 2015Nomad
Our previous trailer had bounce. Two things we did to mostly eliminate it. The first was wheel chocks (homemade from 4x4 and ready rod). This helped alot, especially when we were up on boards to level trailer. We also added the screw jacks under the frame in front of axles or behind axles or both, depending on situation.
The wheel chocks worked well and after making Dad a set, he did not put down his stabilizers after that.. He camps by himself alot so only he is moving around.
On our current trailer, the stabilizers and wheel chocks are enough, no screw jacks needed. I like the Arctic Fox frame, it is well built.
