Dog_Trainer's avatar
Dog_Trainer
Trailer stability while parked
We had a great maiden voyage and made it to fL. we are now parked and using our new TT for the 1st time. It is a triple slide 30' long.
Our biggest disappointment is the bounce we feel when someone walks through the TT even our small dog causes a lot of bounce.
I am on a cement pad the front of the trailer is only about 15" off the ground when level. I have the electric stabilizers and have tried putting a little more pressure on them. I have an X chock on 1 side and standard chocks on the other.
I think this is quite comnmon and so just hoping to get info on products and techniques to help eliminate this.
  • Bounce or wiggle? The stabilizers when set firmly should take out the bounce. You may want to consider a 3rd set in the middle close to the axles. Stacking blocks under the jacks to shorten the extension can help too. The longer they extend the less stable they become.
    Our long tt didn't bounce much but it did wiggle with any movement inside. Solved it by adding JT Strongarms to the stabilizers, all 4 corners. No more wiggle or bounce. Best investment/ mod so far.
  • RoyB's avatar
    RoyB
    Explorer II
    My trailer uses manual scissor jacks on the four corners of the trailer and also a tongue jack. I also use 12x2 boards under each of the jacks.
    I like to lift the front door area just a tad higher than the back side to allow run off water from the air conditioner to drain to the back side of the trailer. My trailer has to be very level from end to end otherwise my access door does not open freely.
    Being manual jacks allows me to be more firm on setting-up each side.
    My trailer is not as long as yours but is pretty firm when setup.
    Roy Ken
  • Longer trailers are going to bounce as the frame will flex a bit. There are 2 things I have done to minimize the bounce. 1) I installed Bal locking stabilizer bars on front and rear Jacks. This almost eliminates side to side and front to back movement. 2) For the frame flex/bounce I use small bottle jacks under the axle equalizer on each side, just putting enough upward pressure to tighten up the axle suspension at center of trailer. Some folks have installed scissor jacks just fore or aft of the axles. I am thinking of doing this myself.
  • I use a 3rd set of stabilizers in front of the front axle....2 x-chocks I made....and BAL stabilizer arms ( their version of JT Strongarms and a hell of a lot cheaper). Its almost perfect....as perfect as possible that is.
  • We installed the Steadyfast on our fiver and it made a huge difference, especially when the washer is in the spin cycle. We also use X Chocks on both sets of wheels. I still feel some movement when my teenagers are moving around but pretty darn solid now.
    Only took a couple of hours to install the Steadyfast system and the company president emailed me to make sure the install went well and gave me his personal cell phone number if I had issues. Now that's service.
  • You cannot expect a trailer to be as firm underfoot as a home. Even a house on pillars has a support at the minimum every 3 feet; and that is with framing far beefier than a trailer.
    suggest X chocks on both sides of trailer.
  • 2 words. Steady fast. Love ours and works GREAT. check out there website
