guidry wrote:
I have TireMinder and the company is good to work with; however, a couple of things:
1. You don't need metal valve stems, some people think you do because of the rotation of the tires will make the stems wobble and cause problems. I haven't had any issues in that regard.
I also have had the TireMinder system for over 6 years and over 10K miles towing w/o issues not having metal valve stems. I do have the high pressue stems that have the part flexible metal stem and use the metal chrome stem cover on them because of my aluminum wheels. IIRC when I orignally got my system one of the advantages from TM is that the sensors were light enough that metal stems were not required.
Larry
