time2roll
Jun 29, 2018Nomad
Run 50 psi until you get load range D then run at 65 psi.
This is cold inflation... before you roll and before the sun is on them for best results. Although if you have been running fast in the hot sun it is still fine to add air if below 50 psi. And suspect a leak if pressure is low while running. Never reduce pressure unless cold.
44,056 PostsLatest Activity: May 04, 2014
