Vulcan Rider wrote:
RJsfishin wrote:
And if loaded to the max or more, add to the sidewall pressure to keep heat down.
I just don't drive in hot weather, period !
That first statement can be dangerous.
NO tire company in the world recommends going beyond the MAXIMUM pressure on the sidewall; that's why it is called MAXIMUM.
If you get into that situation, you need the next higher load range tires.
And then, living where you do maybe you can avoid really hot weather; alas most of us can't so we just need to deal with it properly and safely.
I am a survivor of a 10.00 x 20 trailer tire explosion. Adding more air than recommended is dangerous and foolish. I am fully trained and experienced however failures occur. I'll leave it at that.
