mileshuff wrote:
Maxxis 8008 ST tires have a speed rating of Q, which is 99mph. However, they state that is dependent on load. As you increase speed you need to increase PSI up to the tires limit and decrease load. Check their load tables for what PSI is needed for your trailers weight.
From Maxxis:
"From 66 to 75 MPH – the tire inflation pressure needs to increase 10 PSI (not to exceed the maximum PSI the tire is rated for) but requires no load adjustment.
From 76 to 85 MPH – the tire inflation pressure needs to increase 10 PSI (not to exceed the maximum PSI the tire is rated for) and load should be reduced by 10%."
In other words, the load capacity has to be derated to get the high speed capability... Nobody should be driving 85 mph while towing a trailer anyway.
