RinconVTR wrote:
Oh, so you believe if the Maxis ST in question is at max cold PSI their tire is rated for 99mph?
I have no reason not to believe what Maxxis says in writing. In fact, since it's the manufacturer which does the rating, believing otherwise would be foolish. I do trust that
nevadanick was truthfully quoting what Maxxis wrote.
RinconVTR wrote:
Most TT's and trailers in general have PSI recommendations of max cold. I've yet to personally see one stating less. Look at the sticker on your trailer, prove it to yourself.
Many trailers are near their limits - max PSI is on the sticker because that's what's required to support the GAWR rating with the minimal tires they spec. Put a bigger tire on, or a higher load range, or run at an actual weight significantly less than the GAWR, and there's no need to run at the max pressure, which will only help shake your TT apart.
