mileshuff wrote:
That isn't what Maxxis stated.
Actually, that's exactly what they said.
mileshuff wrote:
They state at max cold PSI at max rated load the tire is rated to 65mph. But if you run well under max load the speed rating goes up. Tire is rated to 99mph (Q rating) if under loaded sufficiently. Take a look at typical car tire specs. Manufactures will usually provide a table showing load vs speed vs PSI.
That's not at all what they said. Let's take a look, quoting
from here, the entire response from Maxxis:
Maxxis wrote:
To ensure your reply reaches the proper destination, do not modify or remove the subject line of this email.
Nick,
"High Speed" is used to differentiate the M8008 ST Radial from other products we offer that are intended for industrial and/or commercial use, in slow speed applications. The Maxxis M8008 ST Radial carries a "Q" speed rating. However, according to the Tire and Rim Association, the U.S. tire industry specification authority, inflation pressures and load specifications in general for any ST Radial trailer tires without a service description, regardless of the manufacturer, are designed and rated at 65 MPH. However, if the speed is higher than 65 MPH, the pressure and load need to be adjusted according to the following guidelines:
From 66 to 75 MPH – the tire inflation pressure needs to increase 10 PSI (not to exceed the maximum PSI the tire is rated for) but requires no load adjustment.
From 76 to 85 MPH – the tire inflation pressure needs to increase 10 PSI (not to exceed the maximum PSI the tire is rated for) and load should be reduced by 10%.
We hope this information is helpful. Thanks for your inquiry and interest in Maxxis Tires.
Best Regards,
Your Maxxis Support Team
Maxxis International – USA
Email: [email protected] | Web: maxxis.com
09/07/2015 20:00
Submission from: Nick
Nick
Unequivocally, they state that the M8008 carries a Q (99 mph) service description. Then, they go on to cover
other tires, which they qualify with the phrase "
without a service description..." What follows is not meant to apply to the M8008, which they already gave a
specific service description for, but to other ST tires
in general. It would make no sense for them to give a 99 mph rating, then describe how to inflation and load can be adjusted to get to only 85 mph.
Edit: Maxxis says the inflation/load/speed adjustments apply to all ST tires, not just Maxxis, and I suspect that comes from the
Tire and Rim Association yearbook. But, I'm not spending $119 to be sure.
