otrfun wrote:
Dick_B wrote:
. . . the length of the trailer has no affect on the tow vehicle . . .
Definitely disagree. A 33 ft. TT has a lot of real estate on each side. Acts like a big sail when there's high side winds. The only thing that counters that twisting/swaying motion brought on by high side winds is the sheer weight of the truck. The heavier the TV the more stability.
We've towed a few 30+ ft 8k-10k TT's with a 1/2-ton (5.5k weight) and 1-ton SRW truck (8.2k weight). The 1-ton SRW truck's almost 3k of additional weight brings a lot more stability to the table when there's high winds.
Lastly, even a trailer that only weighs 8k-10k could be handful for 1-ton SRW truck with a tow rating of 16k **IF** the side surface of the trailer is extremely high with high side winds. At some point excessive side surface area on a trailer can easily make the truck's tow rating completely moot.
Long TT can really affect the TV, in both side winds and with passing semis. It is the fact the pivot point on the TV is 3' to 4' aft of the TV's rear axle that will contribute to sway.
