rhagfo wrote:
Grit dog wrote:
Cummins12V98 wrote:
YEP, a 1500 can tow it but can it "HANDLE" it in unforeseen conditions.
How is it less safe to pull a (the OP) 9-10klb trailer with a 6000lb+ truck rated to tow 11k,
than pulling almost 30k with a 8000lb + truck rated to tow almost 30k?
Seems like you are both at roughly the same % of max capacity...
Two major differences.
#1 Cummins12v98 is towing a 5th wheel which is 100% more stable than a TT in cross winds and not affected by semi's bow waves.
#2 He also has four tires under the hitch, six total.
So magically 2x the tires (more like 1.5x because the little dually tires aren’t rated as high as big srw tires) makes it safer for 3x more weight and more side wall area to catch wind?
