Me Again wrote:
Grit dog wrote:
Cummins12V98 wrote:
YEP, a 1500 can tow it but can it "HANDLE" it in unforeseen conditions.
How is it less safe to pull a (the OP) 9-10klb trailer with a 6000lb+ truck rated to tow 11k,
than pulling almost 30k with a 8000lb + truck rated to tow almost 30k?
Seems like you are both at roughly the same % of max capacity...
So, I drove a 15,000 lb(mostly aluminum) Class 8 Chevy Titan 90 tractor with 65,000 lbs of aluminum trailer and gasoline(8500 gallons) behind it. Was that an unsafe combination? The tractor was twin screw with heavy duty components and tires. 150/1500 can not be counted as heavy duty compared to their bigger brother 250,2500 and 350,3500's. Having the right tool for the job has always been important when stuff happens.
Literally no bearing on the discussion, but cool looking cab over Jimmy! Be fun to have one fixed up to take to car shows and cruises now!
And likely totally “unsafe” compared to today’s tractors based on rvnet warped logic!
(I’m not insinuating I feel it was unsafe,btw)
