gmckenzie wrote:
mooky stinks wrote:
I towed a scaled 8300 lb 35ft Outback with a Chevy 1500 max tow 10 times a year for 6 years. Weight was never a problem but wind was. A couple trips I had to take secondary roads instead of the interstate. Ultimately it’s up to you and your set up. The hitch being dialed in is absolutely critical. Expect days when you won’t be able to relax. It’s certainly not for everyone. If you’re the type of person that gets nervous when your rig makes the slightest move then I would look for something smaller.
I'm similar. 8,200 lbs scaled (and GVW) and 34'4" length. I use a Equal-i-zer 4 pt hitch and spent a good chunk of time getting it set up. Biggest issue I have is porpoising on bad roads, Jasper to Banff or on the Oregon Coast. And no choice for secondary roads.
I'm good, but we are looking at bigger units so I'm looking at 1 ton trucks first.
Get Bilstein shocks, made a huge difference on cement roads for us, we just did the rears but the difference was so big the wife said we're doing the fronts too before we were 200 miles down the road.
As far as OP, my trailer is a few inches longer, no issues in the first 3k miles, I'll have a better idea after our next big trip to Utah and Colorado.
