darsben1
Sep 23, 2016Explorer
mike-s wrote:
Which furnace do you have? One of the common propane ones with intake/exhaust vents on the outside? They don't add moisture to the inside air.
If you have one of the catalytic propane ones (although they're usually called heaters and not furnaces), then they do produce lots of moisture.
But warmer air hold more moisture and when it comes in contact with the relatively cooler windows CONDENSATION will form on the windows.
Respiration will increase the humidity of the air
44,071 PostsLatest Activity: Aug 30, 2026
