deltabravo
Sep 24, 2016Nomad
mike-s wrote:
Which furnace do you have? One of the common propane ones with intake/exhaust vents on the outside? They don't add moisture to the inside air.
Ditto.
It's not the furnace that's causing condensation (on the windows I presume) Condensation is forming on the windows due to the cold outside temp and the small amount of moisture in the air from breathing, or running the propane stove for cooking. The colder it is outside, the worse the problem is.
Some venting is a good thing. I usually crack open the bathroom vent a little bit
44,071 PostsLatest Activity: Aug 30, 2026
